All but one speaker cuts out
profile.country.RO.title
88604034
I have a kinda retro amplifier (TA-AV581) attached to a 5.1 system. After some time all, but the right speaker cut out at the same time. The only workaround is to restart it. Did not change the wiring or other settings on it and it started happening after a longer period of normal use. If I use it on a 2.1 setting nothing bad happens.
Hi there,
It seems you can get help here.
Let us know how you get on.
Best wishes,
M
88604034
Unfortunately it's a wired connection 😕
