Can I change my subwoofer on my surroundsound
Sean.333
I have the SONY BDVE4100.CEK 5.1 Smart 3D Blu-ray Home Cinema System.  And I want to upgrade the subwoofer to an active one I was wondering if this is possible ?
Pascale_F
Moderator
Hi Sean,
Welcome to the community.
I'll see if i can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Win_88
Specialist
Hi Sean,
I took a look at the system specs and it doesn't look like it's going to be possible to use a different subwoofer than the supplied model.
Win_88
Sonyvores
You can upgrade only if it's a passive one. The DAV doesn't have connection for active subwoofer
