CMT-BX70DBi Hi Fi Fault
SteveJGormley
Hi I cannot stop the standby light flashing even after resetting it, so Hi wont work at all,on turning on just clicks twice,then flashes.Problems!
Thalamus.
Champion
Hi SteveJGormley,
welcome to the Club VAIO Questions & Answers forum..:smileyhappy:
Have you tried the following...
Unplug the power cord & check the following items..
  • Is the voltage selector set to the correct voltage.?
  • Ensure the original supplied speakers are connected correctly.
  • Ensure the ventilation holes on the top and rear of the hifi are clear of dust and obstructions.
  • If you have an iPod or iPhone connected remove it from the dock.
If none of the above helps then either let us know.?
Or
contact Sony support for further advice, for contact details click here
Thalamus.
Champion
Hi SteveJGormley,
Or
oldskool1972
I have this exact same fault and wondered if you'd found a solution/fix for it yet?
Thanks in advance for your time,
Best regards,
Carl.
