CMT-ED1A
Nick__07
CMT-ED1A
Recently bought this micro hi fi - second hand.
Love it; in the main plays very well but quite fussy about CD quality - doesn't tolerate scratches or marks on CD's well.
One problem has arised - the centre plastic piece which sits with CD when playing (such is my audio system knowledge I have no idea what this piece is called - about diameter of a 1 pence piece; perhaps 3 x as tall . .?)  This centre piece has come loose and each time I remove a CD it is stuck inside it.
Any ideas if this piece can be stuck back down safely and, if so, best glue/sticking material to use?
Any suggestions gratefully received.
Thank you
IamNic
Hello @Nick__07,
while I can't answer your question, I think the thing in question is called 'spindle'.
- Nic
