CMT-S20B
josteph10
CMT-S20B
I can't set an alarm time, it says to use different buttons in the guide and on-line and neither works.
Pascale_F
Moderator
Hi josteph10
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Win_88
Specialist
Hi josteph10
Are you trying to set a play timer? You can do so using the Timer Menu (it's a button on the remote control),
It may help to tell us at which stage exactly you get stuck.
I found the steps in the Manual here: https://www.sony.co.uk/electronics/support/res/manuals/4460/44609281M.pdf
Win_88
josteph10
I have managed to set the alarm but it is not easy.  The << >> buttons seem to not have a bounce supression, so the system seems to jump through the steps.  So for example, after many tries, I had set the STop time but couldn't get the Start time.  I eventually got it to accept Start time and it now has a play time and works.  I now need to be able to stop it - a new problem.
