Flashing standby light. DAV-S888 AV System.
profile.country.es_ES.title
AllynMD
After a power cut the standby light on my DAV-S888 now flashes and the screen is blank.  I've tried disconnecting and reconnecting but the unit still doesn't respond to any input.  Does anybody have any ideas for a fix?
japenfo71
Hi there,
Did you have any luck fixing this?
I have the exact same problem now.
