Ht st-5000 with separate SRS X99 speakers
Kwt1947
Thinking about having the 2 SRS X99 WiFi speakers in the same room as the sound bar. Will it be possible to link them together without echo or interference between the amplifiers in all units.
Marino.Manolo
Genius
They are all compatible with the Wireless Multiroom function, then it will depend on how you place them.
Manolo
profile.country.GR.title
giorgakis30
It s very sad my friend for sony not to have in their flagship sound bar rear speekers. I want this soundbar but with sorround and upfiring speekers. I might go with samsung q950t or lg sn11r. The truth is that i m listening quite often about connecting issues with bravia 65xh 9505 (my tv) and samsung q 950 t. Anyway, hope to rethink sony this problem and you ll find solution to this.
