MDS JE 470
profile.country.IE.title
dearg1
MDS JE 470
Hi
I know havethis is old equipment , but hopefully there might be some enthusiasts out there.
I recently bought a minidisc player which won't turn on . This is  the second model which appears to have the same fault.
Essentially when powered up the red light turns on , I hear a slight click , but then nothing. No error messages , no display at all . I opened it up and cannot see any damage at all , no it looks almost new. Tried remote , nothing , tried putting in disc , dead , there doesn't appt to be any internal fuse and very limited information on the internet .
However a number of posts people are reporting similar issues, my question is , has anybody come across this and is it fixable. Is it bad connection , solder joint, capacitor etc.
Any advice greatly appreciated
Regards
Hopefully some other community members are able to help with this. In the meantime you could also ask the customer support team for advice via the contact form here.
