MHC V41D Audi input out or synch from source
M5tski
I am connecting to the V41D RCA inputs from dj mixer, selecting the Audio In function. Sound is good quality however there is approx 0.5 second delay. Clear delay between earphone of mixer and V41D sound output, causing beat mixing to be impossible.
Have tried TV function, same result, and also tried using microphone input is the same. Also suspect the lights are syncing in time with mixer/earphone but just delay with sound. Is there a fix for this? Purchased purely to connect turnatables and mixer to.
batee5
Specialist
Hi M5tski,
Welcome to our community!
I believe this delay is due to internal processing time required in order for the system to produce the sound from this kind of connection.
Regards,
Batee5
