need some advice
georgeb9896
need some advice
Some years ago, I bought a HIFI system,  MHC  VX333.  It has worked very well, but the FM aerial is missing.
The aerial is described as a  FM 75 Jack type A.  Please see picture from the user instruction  manual.
Can anyone help in advising me as to where I can buy a new aerial?
Peter_S.
Genius
If you're looking for the FM antenna: just use a wire that is around 90 cm long - that's it.
Peter
