Problems with bluetooth on HT-CT60BT
James_T
Hi, I can't seem to pair any device to my HT-CT60BT sound bar via bluetooth. I've tried my iPhone 5, iPad and MacBook Pro. None of them pick up the sound bar and both are in bluetooth pairing mode. Any suggestions?
4 REPLIES 4
Hi there
When pairing, you have to be pretty close to the soundbar.  Also press "Bluetooth" on the soundbars remote control.
See pages 16-20 of the manual : HERE
Also, at what point does it fail?
James_T
Thanks for the reply.
Yes, I am sitting my phone next to the sound bar. The sound bar is in bluetooth pairing mode (i.e. blue light flashing) and my phone is searching for a device. It is picking up other devices (i.e. my computer) but it cannot pick up any signal from the sound bar.
Hi there
To be honest, I have absolutely no idea why its not working :cry:
In the manual it states that the device must support A2DP.  iPhone 5 does: http://support.apple.com/kb/ht3647
Unless another forum member has any other ideas - suggest contacting Sony Support : HERE
sinclair_scott
I have the same problem.
it used to work.
