PS-HX500 turntable (speakers for)
Laity4453
I have just purchased a PS-HX500 turntable but am unsure which speakers I should buy? Does anyone have any suggestions? Thanks
6 REPLIES 6
Marino.Manolo
Genius
Forgive me if I ask you but do you know you need an amplifier?
Manolo
Laity4453
Hi Manolo. Yes, I have an Amp.
Marino.Manolo
Genius
In this case you should enter the specifications of your amplifier here if you want someone to answer you.
Manolo
Laity4453
Thanks Manolo. The Amp is a Graham Slee Gram Amp 2 Communicator...not sure of specs...as you can tell, I'm a bit of a tech dinosaur!!
Any help would be appreciated!!!!!!!!
Marino.Manolo
Genius
But that is only a "Pre" :flushed:, the audio cables must then be connected to an amplifier...
Manolo
Sonyvores
You should give us more detail about your set up.
You're showing us a  turntable pre amp so it's not usefull to answer your questiion ^^
