Reset cmtbx70bdi
sestosg20099
Reset cmtbx70bdi
How do I reset this system?
sestosg20099
Joe_Dohn
Specialist
Hi @sestosg20099,
You can find the steps in the Manual (second page, first section of the right half).
Hope it helps!
- JD
sestosg20099
Thanks JD
