Sony RCD W100 VD Recorder
David122
Why does the Red Rec button not work when I as m labelling track numbers should it say something on the Display on CD Recorder?
4 REPLIES 4
TheMaze
Community Team
If you're performing a Synchro-recording, you won't be able to label while recording.
Also, track length must be at least 4 seconds before labelling manually while recording.
David122
Here's My Remote control IMG_20240512_180636400_MFNR.jpgIMG_20240512_180636400_MFNR.jpg
TheMaze
Community Team
Did you make sure that you're not performing Synchro-recording when trying to press the record button while labelling a track?
David122
Yes I did not use it All Soted Now Thanks.
