Sony rcd-w100
Mickoz1974
Sony rcd-w100
i have a Sony rcd w100 basically the left side the player using commercial CDs I can play two straight through no problem, on the third or forth cd half way through a random track it goes straight from that one to the middle of another one. Turning the player off for a few minutes and turning it back on it’s plays the cd all the way through and the next then does a random skip again. I’d like to repair this problem as I love the recorder. I did contact Sony they said it’s to old to repair.
EdwinaU
Moderator
Hi Mickoz,
There's some basic information about this model in the guide here. Hopefully someone in the community will be able to offer you some tips to help. Good luck!
Best wishes,
Ed
Mickoz1974
Took it apart cleaned it and it seems ok, I’ll try and get another recorder if this fails anyone know the Order of Sony audio cd recorders rcd w100, w3, w1, w500 etc interested in the order they were made.
