Sony STR-DN1080 "Provisioning Server Status: Failed"
profile.country.SE.title
pirayan
After the latest FW update I cant use the streaming services Spotify and Chromecast. All other Chromecast and Spotify Connect devices on the network works like normal.  (inc. other Sony devices..)  Anyone that have a solution?  At the moment I have connected a Chromecast Audio to the receiver, however that device is needed elsewhere ... 😐
Br
7 REPLIES 7
HannahEd01
Community Team
Hi pirayan, try a simple power reset (unplugging everything and disconnecting from the mains). Try restarting your router as well.
pirayan
Thanks for your feedback however that have not solved my issue.
Bat_Rick
Do you see any error messages when you use the streaming services, or just a black screen?
pirayan
It's a black screen showing a progress bar , connecting to internet content server (1/3)
Bat_Rick
Could you try to connect the amp to another network *smartphone hotspot for example?
pirayan
I have 6 other Chromecast/Spotify devices including a Sony Tv that stream without any problems. I would assume that this device works just like the others ...
Pentium_Gladio
Specialist
Hi Pirayan,
It is always better to test a different network as the amplifier works differently than the other devices. This could just function as a test. Let me know if this works out for you.
Regards,
Gladio
