Sony TC-K511S
Sony TC-K511S
Hi all, i hope someone can help. I have the tape deck TC-K511S. (i know its old) It has stopped playing or rewinding. the bit that insert to the tape spool are stuck and wont move. i took it apart and found a spring had come off. iv looked but have no idea where it goes. does anyone know where i can find diagrams of the motor so i can find out where the spring goes??? Thanks
 pics can be provided it needed.
I should say, the motor works it just seems stuck.
Hi there
As its an old tape-deck - I dont think Sony would have an issue me uploading the service manual for you.  See attached PDF.
Good Luck :slight_smile:
Thanks a lot. Hope i can fix it as even though its old iv hardly used it.
