BDP-S185
jsquires1990
BDP-S185
I have a Sony Blu-Ray BDP-S185! Sometimes when pressing buttons on the remote control it seems to do respond in a completely different manner, also when just watching something the player will go back to the home screen...
Is any body else experiencing these issues? Or is it just my particular machine??
Thanks Guys :slight_smile:
verdig
My BDP-S185 is a little slow, so you have to wait a little while once a button is pressed, but it seems to always do the action specified by the button pressed.
It has never gone to the Home screen whilst watching something, unless I have pressed the Blue "Home" button first.
I would make sure you have the latest software update then do a reset to factory default.
If you still have problems after that there is probably something wrong with it. :slight_frown:
