BDP -S5200
Niteroi1974
BDP -S5200
My dvd blu ray player BDP S5200 is quite old but was working fine. Until few days ago when I was denied access to Internet even I’m connected to.  The problem is on the network access . On the connections server settings is blank, and when I do the network diagnostic, they cant find the server. I don’t know what is the problem. Someone put a link for a solution but when I click was blank. I saw a lot of complaints about this subject but I cannot see I saw any solution. Maybe the only way is forget about this Sony DVD player and never again buy anything from them. If anyone can help me I will be very grateful.
LightFoot
Specialist
Hi @Niteroi1974
Are you running the latest firmware? You will have to update using the USB method if an update is required if you cannot connect via the Internet.
https://www.sony.co.uk/electronics/support/home-video-blu-ray-disc-players-recorders/bdp-s5200/downl...
Niteroi1974
Hi
was a good advice but i didn’t try it because I found out the reason I couldn’t access SEN , even everything was saying that I had access to Internet, my Internet speed was too low!
when I sorted out, everything is running smooth!
thank you anyway
