BDP S6200 Menu sceen judder
efiste2
Since I have had it from new the menu screen on my BDPS6200 does not flow or scroll freely,  it moves from icon to icon very jerkily. Is this a fault or a settings issue. My outgoing BDP S350 scrolled perfectly as does my PS3....
Thanks for any advice
MK_Slinky
It should flow smoothly though whether this is actually a fault I can't say for sure.
Maybe the best option would be to RESET your device and see if that clears the problem.
Here's how:-
  • Open the HOME menu on your BD Player and scroll left to SETUP (Toolbox Icon)
  • Scroll all the way down the list until you reach 'RESETTING'
  • Click OK on your remote and when asked RESET ALL SETTINGS.
  • When complete, power OFF your player and disconnect from the power supply for 1 minute
  • Re-connect the power and retest if the issue is cleared.
Please do come back and let us know if this helps.
The User Manual is your friend..., seek forth and ye shall find answers. Can't find any? Join the club, we have all the answers here, occasionally they're even right! :wink: Dr.Slinky McVelvet - Inventor of the word 'Mellifluous' - 30.12.14
