BDP-S6700
chrisbwhittle
BDP-S6700
My  new BDP-S6700 Blue-ray player will not output audio on some of my DVDs. The player is connected to my Hi-Fi amplifier. Blue-ray discs & CDs produce audio.  Of 16 DVDs I've tried 7 do not give any audio.  All give video on my TV.
If the coaxial connector is removed from the Blue-ray player and connected to the DVD player (Sony DVPSR150) all the DVDs give audio.
Vanilla_
Hi chrisbwhittle,
I'd recommend that you check if those discs are compatible with your old DVD player. I've found the playable discs and formats on Page 9 of the user manual here:  https://bit.ly/2VEstxf
Vanilla_
