Bdv-e380 getting use to it........
Bearsparko
Hi, I have couple of questions. I have just bought the system and its all set up bt there is some stuff I don't understand.
1. When I cycle through the sound modes I can only see the mode on the head unit screen and not the tv? Is there a setting I can change so that I can see it on the tv?
2. I have connected the head unit to my sky hd box with an optical cable. Is there any way I can check to see that it is functional? Are there any settings to configure.
3. What are the 2 volume controls on the remote for? When I touch either one the Sound of the overall system changes and I can see the display on the head unit screen goes up or down accordingly? I should be able to control the tv and Bdv separately but it doesn't see to work on mine. Btw, I am using a Sony Bravia tv.
Overall I really like the system, but I need to understand these points.
Can anyone help?
Thanks.
Bearsparko
Ok, I can see that some features only work when playinga bluray disc.  The on screen selection of sound mode is resolved.
But I still don't understand my other two questions.
Oh yeah, and I have just found out that my new purchase has a fundamental flaw in its design with respect to the lip sync issue.
Please help.
Thanks.
