BDV N590 doesn't turn on automatic while TV starts
profile.country.de_DE.title
Waldemator
Hello,
I hope you can help me. I connected my new BDV-N590 through the ARC-HDMi port to my TV's ARC port, everything works fine. The only problem is, I always have tu turn on the system manually, it doesn't turn on automatically while my TV (Samsung UE55D6500) turns on. Turning off works perfectly, if I turn off my TV the system also turns off. Any suggestioins?
profile.country.FR.title
ClarkLong
That's normal because the TV is "THE" componant of a the home theater that's the only one that always needs to be on... Turning it on won't turn on anything else on but if you turn on anything connected to it, it will also turn on the TV.
Just change teh way you use your system and istead of turning on the TV first, turn on the HomeTheater
