Connect audio from ubp-x700 (blu-ray player) to ht-sf150 (sound bar)
paul.deadman
Is it possible to connect the audio HMDI socket on the UBP-X700 (player) to sound bar HT-SF150 which has a HDMI ARC input.
EdwinaU
Moderator
Hi Paul,
Welcome to the community.
We will check this and get back to you when we have more information. Maybe some of the other members will have some experience with this set up that they can share too.
Best wishes,
Ed
The_Black_Rose
Specialist
Hi paul.deadman,
I've had a look into the connection guide of the Blu Ray player, it can be connected to a sound bar via HDMI cable to pass the signal through to the TV. You can find the connections on page 12 of the Manual through this link: https://bit.ly/2nVp4ep.  However, this method of connection will not apply while using the HT-SF150 sound bar, as it doesn't have a HDMI in jack, it only has a HDMI out ( ARC ) jack, which means that it can only output the sound received from the TV. So if you wish to connect both devices, I'd recommend connecting the Blu Ray to the TV via HDMI cable and connecting the sound bar to the HDMI ARC port on the back of the TV via HDMI cable as well.
Cheers,
The_Black_Rose
