How can an internet connection be made on KDL40EX503 using wifi card in PCMCIA slot?
geordieski
How can an internet connection be made on KDL40EX503 using wifi card in PCMCIA slot as opposed to a cable or dongle connection. We can't find any reference to using this slot on the i-manual. Thanks
Tags (2)
Catmambo
It can't I'm afraid - have to go via Sony wifi dongle or Ethernet/homeplug configuration.
Catmambo
