mkv on smp n100
profile.country.ro_RO.title
alexandru_burlacu
mkv on smp n100
Hi there! I have bought some time ago the smp n100 media player. I just got the chance to test it now and I may say I am verry disappointed about the device. I have searched before and I was glad to see it can play mkvs encoded at most L4.1. This is the output for one mkv encoded L4.1 I tested and got the silly message "File corupt or unsupported".
H:\MediaInfo [mkv info]>mediainfo p.mkv
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 8 frames
Muxing mode                              : Header stripping
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 1h 52mn
Bit rate                                 : 6 869 Kbps
Width                                    : 1 280 pixels
Height                                   : 544 pixels
Display aspect ratio                     : 2.35:1
Frame rate                               : 23.976 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.411
Stream size                              : 5.24 GiB (80%)
Writing library                          : x264 core 65 r1057M 5f8a149
Encoding settings                        : cabac=1 / ref=8 / deblock=1:-3:-3 / a
nalyse=0x3:0x133 / me=umh / subme=9 / psy_rd=0.8:0.0 / mixed_ref=1 / me_range=24
/ chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offse
t=-2 / threads=6 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_ada
pt=2 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40
(pre) / rc=2pass / bitrate=6869 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51
/ qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000
/ ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Codec ID                                 : A_DTS
Duration                                 : 1h 52mn
Bit rate mode                            : Constant
Bit rate                                 : 1 510 Kbps
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Bit depth                                : 24 bits
Compression mode                         : Lossy
Stream size                              : 1.18 GiB (18%)
Default                                  : Yes
Forced                                   : No
Text
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Title                                    : Romanian
Language                                 : Romanian
Default                                  : Yes
Forced                                   : No
Can somebody explain what encoding this box really supports? I am on the point of buying a Sony TV for easier sync with the smp, but if this encoding is an issue, I will surely reconsider, even about the MP. Very disappointed so far!
0 REPLIES 0
