NSZ-GS7 - A few questions
siddys
Hi all,
I have just ordered a NSZ-GS7 and have  a few questions ;
1. Did the recent upgrade update to ICS?
2. Did the recent upgrade include a Netflix App (In the UK)
3. If a Netflix app has not been provided , has anyone tried coping the Netflix .apk from another device and tried to install? I intend trying to copy and install Netflix from my Logitech Google TV box
4. Is Skype available for download from the Play Store, if so has anyone installed and used with a webcam?
Thanks in advance
Message was edited by: siddys
Catmambo
Hi Siddys
  1. No upgrade for ICS planned as there is nothing in ICS that relates to Google TV, so its a pretty pointless upgrade. Work has started on a Jellybean upgrade though, but no launch date as yet.
  2. Yes, Netflix is now on the device, following the latest upgrade
  3. Not sure if Skype is available yet, you could drop them a note and see if they are working on a specific application for GTV. I'd be suprised if they aren't to be honest.
Hope this helps
Message was edited by: Catmambo
Catmambo
Hi Siddys
Hope this helps
Voukvouk
Also, does anyone know a Music/Media player that will play through the home net work? I can't believe GTV has been released without a descent music player! RUBBISH!!!
