Problem with firmware update on STR-DA3600ES
neilbr72
I tried to update my av receiver and everything seemed fine until the unit seemed to reset itself - following this i get sound but no picture - when I connect a pc on the network the firmware level says firmware is version 1.027 the update was for version 1.030?
the unit is stuck in gui mode and i can't switch this off to enable pc update and also get no video outpu t from any hdmi channel however sound is fine?
does anyone have any ideas?
Thalamus.
Champion
Hi neilbr72,
are you able to reload the firmware update.?
If not then I suggest you try contacting the service centre for advice..
Thalamus.
Champion
Hi neilbr72,
