RDR-HXD890 also stuck in standby
13Christopher13
Can anyone suggest a solution please. My recorder seems to be stuck in standby with the words UPDATE on the panel.
Do I just wait or try a factory reset?
This has just happened, was working fine last night.
Thalamus.
Champion
Hi All,
before posting any further comments please read this thread
***RDR Stuck in Update or no Digital channels issue***
I have locked this thread in a hope that we can limit the number of thread so to avoid confusion & make it easier for users to find the latest information..
9 REPLIES 9
It is a universal problem that they are aware of.
http://community.sony.lu/t5/Home-Cinema-Projectors-Players/RDR-HXD870-stuck-in-UPDATE-mode/m-p/69710... has a thread about it.
Peter291
I have both a HXD870 and HXD 890 and both have lost digital sighnal today. - I've spend most of afternoon reading the mannuals and trying to retune so not very hapy if this is a fault that Sony have caused.
anneprice
Same problem here.  Couldn;t get anything out of it last night.  It STILL shows 'update' this morning!
pewrigh38
use the recorder power button trick to get it out of UPDATE mode
set location to france in easy setup to get the channels working
but no epg as yet, awaiting a permanent fix
park1nsr
Whats the recorder power button trick - sorry i'm not aware of this?
Catmambo
pewrigh38
read the other threads and all will be revealed, its been posted dozens of times already
park1nsr
Brilliant thank-you, both of my HXD890s appear to be working now - thanks everyone
Thalamus.
Champion
Hi All,
