RDR now working - success!
Safficat
RDR-HXD 970 was stuck in update. I am not a techie but followed the advice from posts below and switched it on.  It flashed the word 'LOCKED' and then update.  I pressed the stop and on/standby together several times and it did not change - but then pressed the stop and held it down.  It then flashed up 'UNLOCKED' and the thing fired up and the HDD blue light came on. I checked the programme guide and it all came up as it should do so I have not re-tuned it.  I have not tried to record anything yet - but am hopeful it is now sorted.
Thanks to the community colleagues for all their advice and thanks to MTV LINCOLN who called me first thing this morning to offer support.
0 REPLIES 0
