SA-CT260H sound bar and wireless subwoofer problem
stevieboyracer
Hello I own a SA-CT260H sound bar and wireless subwoofer. They are pairing up fine and I have a solid green light on the subwoofer but the subwoofer volume is very low and sometimes no sound at all even when turned up full. I can briefly get the sound to kick back in full power for a split second when I adjust the subwoofer levels in the menu but then it instantly drops back down again or goes off totally. There is nothing obstructing the signal, I have tried re-setting the sound bar and also re-pairing the sub and sound bar but I still have the same problem. Does anyone know how to fix this. Thank you
EdwinaU
Moderator
Hi there,
Welcome to the community.
Please try the tips here to see if they help with your speaker sound issues and let us know how you get on.
Best wishes,
Ed
