Sony BDP-S186 aspect ratio problem
John1231
Hello!
I have a problem with my BDP-S186 bluray player while watching content from USB.
The media is in widescreen format and intended to be played with black bars, but the player seems to stretch the image to fill the entire screen, therefore distorting the image, how can i stop this from happening ?
4 REPLIES 4
John1231
Hi there
You need to set your screen settings in the setup menu as follows :
TV Type = 16:9
Screen Format = Original
Aspect ratio = Letter box
Alternatively, adjust settings to your liking
See Page 15 of the manual here =
http://pdf.crse.com/manuals/4290282121.pdf
Note: I know the manual is for the BDP-S185 (the UK version) - Or your countries manual here : http://www.sony.co.uk/support/en/product/BDP-S186/manuals
John1231
Thats factory settings, no luck still stretched 😞
Could it be your TV settings?
Do DVD's/Blu-rays play in the correct aspect?
Have you verified that the video file is in the correct ratio?
