Sony Blu Ray Player
steveqae
Sony Blu Ray Player
I have a Sony Blu Ray Player BDP-S6700.
When I create a dvd on my computer and create a menu on the disk this shows when I put the disk in the player, however I cannot get this menu to re-appear without ejecting the disk an putting it back in. How can I get the menu back?
Pascale_F
Moderator
Hi Steve,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Win_88
Specialist
Hi Steve,
The remote control has a button labeled pop up/Menu which has the function of bringing up the DVD main menu. Does it work with other DVDs? What happens when you press it when playing the disc you made?
Win_88
steveqae
If I press the button called top menu it brings up the disc menu on a comercial disc but not on the ones I make myself. The popup menu botton does nothing.
