Sony S Air problems
Sony S Air problems
Hi I wonder if anyone can help. I bought an adapter wire that connects to the iPod dock in the Sony S air system and then to an ipad or other music player. However when I connect it up I cannot get it to work. Can anyone offer a reason for this. Thanks.
Thalamus.
Champion
Hi Nickjpsmith,
welcome to the Sony User Community Forum..:smileyhappy:
As far as I am aware the ports are only audio out on the Sony S Air speakers, if you want to play audio from your ipod you need to use the S-AIR dock..:smileyconfused:
Hi there
I dont have any knowledge on the Sony S-Air systems.  However, for someone to advise you properly, you may need to include more information.  For example, model numbers of equipment concerned, how have you connected it up, do you get any error messages, and any other relevent information that you can think of to assist.
Cheers.
Thalamus.
Champion
Hi Nickjpsmith,
