Soundbar sony ht ct80 usb blinking
profile.country.BG.title
Jodo01
I have problem with my sound bar. I few minutes ago i connect it with usb flash and press the button. Now this usb indicator light just blink and I cant do anything. I need some help. Even I cant reset the system with sw volume +night.
Pascale_F
Moderator
Hi Jodo01,
Welcome to the community.
I'm just going to try to find some help for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Win_88
Specialist
Hi Jodo01
That's strange! Have you used this USB drive with the sound bar before?
I'd say remove it from the port, unplug the sound bar from the mains for a few minutes, then plug it back in again.
After that, try the steps to reset on page 22 of the manual: https://www.sony.co.uk/electronics/support/res/manuals/4567/45674732M.pdf
If the same thing keeps happening, I'd recommend contacting your local service centre: services.sony.co.uk/support/en/repair/asc
Win_88
Jodo01
Hello,
No, I havent used this flash drive before, actually that was my first time of using flash drive to this sound system.
I have already tried those methods which you mentioned. It does,nt work even when i tried to reset the system.
Its still in warranty period, so I send it to the service. It looks that not all flash devices are accepted by this system.
Thank You!
