Speaker Extension Cable for BDV-EF200
kjharve
Hi all,
I recently bought a Sony Blu-Ray Home Cinema System (BDV-EF200) but the cable is too short on the speakers. I've trawled eBay and Maplin but can't find any extension cable or connector to do the job.
Does anyone know if these are available? If so, what should I be searching for as I've had no success so far.
Here's an image of the jacks.
Cheers,
Kevin
Bravia55HX
easiest way is to buy some speaker cable from the likes of maplins and splice it in to the wires you have, you an twist and tape the joins with electrical tape, you can also solder the joins if your feeling confident enough, failing that, find someone willing to do the work for you.
kjharve
Any ideas?
Bravia55HX
