Streaming Music to BDP-S6200
efiste2
Is it possible to stream music from my Ipad to my Sony BDP-S6200 over my WIFI connection, and hence it will then play through my sound system or soundbar......and if so how do I set it up.
Thanks for any advice
Hi there
You need an app called iMediaShare.
Available on iTunes :
https://itunes.apple.com/gb/app/imediashare-personal-stream/id710578942?mt=8
These instructions should help you set it up:
https://us.en.kb.sony.com/app/answers/detail/a_id/34421/~/how-to-use-the-imediashare-application-on-...
MK_Slinky
In addition to what Quinnicus has mentioned above, if your sound system has AirPlay you can stream directly from iTunes on your iPad bypassing your BD Player altogether.
Some of the Sony STR range of receivers have this feature. I use it on mine quite a lot and it sounds pretty good!
The User Manual is your friend..., seek forth and ye shall find answers. Can't find any? Join the club, we have all the answers here, occasionally they're even right! :wink: Dr.Slinky McVelvet - Inventor of the word 'Mellifluous' - 30.12.14
