42W829B - Favourites
Daleos
Ok, so I've added a bunch of channels to my 'Favourites'
How do I access them? Is there a button anywhere that displays just my favourites? I know about 'Discover' but I'd rather just flick through them without the massive ui getting in the way.
Can I set my Prog up/down so that it only goes though my favourites?
I really don't want to see all those sport and shopping channels *EVER*. How do I permanently hide them from 'normal' use?
Hi there
As I have last years (2013) TV, it might be different - but for me, If I add Freeview channels to a Favourites list, I can use the [Prog +/-] button on my remote control, then scroll across using the "right arrow" button on the remote control to my favourites list.   All favourite channels are then displayed.
Hope this helps
Hi there
Hope this helps
