Annoying dimming on KDL46HX803
finlayjay
Hello all, just joined and was interested to see if anyone could suggest the reason my HX803 has this constant slight pulse/dimming when viewing .I thought it was the auto light sensor option but that is already switched off.Very slight but always there. Thanks in advance.
Bravia55HX
have you turned off the Ambient sensor as well?
finlayjay
Wasnt aware they were 2 light options/settings ,i will go back for a look thanks.
Wher will i find the ambient sensor ?
Bravia55HX
ok, well the technical specs say the tv has it so i would imagine it will be found in Eco settings somewhere.
