Are firmware update changelogs complete?
hcr_hassen
Do firmware update changelogs ("Benefits and improvements" as Sony calls it) usually mention all the changes?
I wonder if it's worth the trouble to update when all the listed changes are "This software version improves the Hybrid Broadcast Broadband TV (HbbTV) and Network applications".
Hi there
The information that Sony provides on the Support Pages are a very brief summary.  The FW updates usually contain many bug fixes and its generally advised to update your TV to the newest firmware anyway.  Quite often this is done automatic (unless you have switched that option off)
PS: And no, I dont have access to the full change-logs.
Hi there
hcr_hassen
Thanks. :slight_smile: Silly that they don't release the details.
I don't have it set to autoupdate, and anyway the TV isn't connected to the internet normally.
