Audio out
naallen31
Audio out
How can I link my Sony Bravia TV, KDL-V32A12U, to my Sony Home cinema, DAV-DZ500F? I have a scart lead connected to the smart link connection at the rear of my TV.
Hi there
Am I assuming that you are trying to output audio from the TV through to the DAV system?  If so, SCART is only outputted from the DAV system and Inputted to the TV.
You will need to connect a set of audio composite cables (Red/White) from the Audio Out socket on the TV(see page 36,37 and 26 of the manual : HERE)  to the Audio IN ports of the DAV system (see page 27 and 62 of the manual : HERE)
Hi there
