blured picture when playing xbox360
jonesey63
hi all,  just bought a 3d tv model kdl46hx803 but what is bugging me is that when i'm playing my xbox360 (zombies) on screen,when you go to turn around the edge of the picture goes blurry which follows you as you turn! anyone know why this would happen as i've never come across it before on a cheaper tv? i've sometimes noticed this happen while watching tv if the shot comes quickly from either side. any thoughts  many thanks mark
Bravia55HX
sounds like you need to go into settings and turn off any picture processing features off like motionflow, its not to everybodys taste, personally i leave mine off but i dont play games but find this makes movies more natural
Bravia55HX
