Bravia KDL-26S2030 re HDMI IN
I have the above model. I have a virgin TiVo plugged into the HDMI IN.
I'm thinking of getting a NOW Tv box which comes with an HDMI cable. Do I have to unplug the Tivo every time I want to use the Now Tv box? Could I plug the now tv box into the HDMI socket marked PC? This one is next to the HDMI IN with the TiVo connected.
Any other options?
Catmambo
4 REPLIES 4
Catmambo
Thanks. That looks good.
The people at Now a Tv said to use an av cable. Not that I know what that is either LOL
Catmambo
Yes, an HDMI splitter will basically ensure you are getting a high quality digital signal and remove the need for you to have to switch cables between boxes. You may need to get an extra HDMI cable, as you'll need 3 with this setup though.
Thanks. Yes I'd assumed another cable was reqd. This seems the best option so will give it a go
Thanks for your help
