Bravia Software
chrisbrowe
Bravia Software
I notice that the software on my Bravia KDL-32EX403 has changed to
PKG4.114EUL-0108 which is newer than the software listed in support for the model, what's changed in this version, please?
Thalamus.
Champion
Hi  chrisbrowe,
As you have discovered the firmware on Bravia TV's connected to the internet normally get automatically update before Sony amend the information on the support site..
Unfortunately all I can suggest is that you keep checking the support site until the download section gets the updated info..
Thalamus.
Champion
Hi  chrisbrowe,
