Can my UK purchased Sony TV work in New Zealand?
davidpbowles
Hi, I'm a happy owner of a Sony LCD digital colour tv, model number Kdl32cx523 and was wondering if this will work and recieve all tv channels in New Zealand.
david
Bravia55HX
Hi again,
you could contact sony support under the support tab at the top of the page for further clarification,  or you can check the tech specs below (near the bottom of the page) for tuners in yours.
http://www.sony.co.uk/product/tv-80-32-lcd/kdl-32cx523/tab/technicalspecs
Bravia55HX
well the voltage is the same, you may need an adaptor to plug into the mains, the only thing i'm uncertain about is the inbuilt tuner, you may need a pvr or set top box from their region for it to work.
davidpbowles
thanks for that- do you know where i can find details of the inbuilt tuner?D
Bravia55HX
Hi again,
