Cannot HD record...no digital guide
rutcook58
I have a sony bravia 32CX523 have registered my drive on the TV with no problems. But when I try to record, it will not let me go into the guide. Says I need digital. I know I am probably being stupid but we have freesat  via HDMi 1, does this mean that unless I am using freeview via an arial, I cannot use the HD record?
Very annoying as I have foormatted the drive which I bought especially to allow this function. If anyone can advise me I would really appreciate it
Correct.
As the TV has a Freeview Tuner, and the HDD is registered via the TV. To record, you must go via the Freeview built into the TV.
Maybe investing in a Freesat PVR might be better in your instance?
Sorry to be the bearer of bad news.
rutcook58
Thanks..had the feeling that would be the case! will now have to reformatt the drive so can use it elsewhere.
:slight_frown:
