Cleaning
Cleaning
Can anyone suggest a method or product to clean the screen without leaving streak marks?
Thalamus.
Champion
Hi Magicglenn,
Welcome to the Sony User Community forum..
I find using a microfibre cloth works well & for the more stubborn marks I just breathe on the screen then clean with the microfibres cloth..
Hi there
In addition to what Thalamus said above, unfortunately there is NO easy way to clean your TV.  Please do not be tempted in using products like Windex or any other chemicals, it can damage your TV (and over a period of time too).
2 x Microcloths
  • 1 very slighly damp - this is to remove any spittle or oil residue from finger marks
  • 1 dry - use lighly on the tv screen (when OFF) and basically keep wiping lighly until clean.
Chemicals can ruin the coating of the screen, as well as drip under the frame of the screen too.  Here is a YouTube clip of water damaged TV
Cheers folks. Appreciate the advice.
