Will the UWA-BR100 wireless adapter allow me to connect to my laptop on a KDL40V5810?
Solved! Go to Solution.
this must be the second time i have heard drivers mentioned and i dont believe they are nessessary, i've connected using d-sub on 2 big tv's now as i dont have HDMI on the laptop and have never been prompted for drivers, in any event if your on windows 7 it would find them for you if it needed them but im sure it wont.
no, it will not, the only options available to you is either a d-sub connection or HDMI.
if you connect with HDMI Cable do you need a driver for your laptop and where can you download?
i have KDL-40W4000
