Connecting HD Freesat, HD DVR and Bravia.......wits' end !
ColinWB
I have tried, I think, every permutation but without luck - there may be a fault but I wouldn't know where.
I have : KDL 32EX600  plus an HD Freesat box with 1 x HDMI slot, 1 x SCART + RF co-ax's plus an LG HD DVR with 1 x HDMI and 2 x SCARTs and RF co-ax's.
I do not use a  co-ax aerial.
HDMI #1 port on Bravia appears to be u/s.  I'd be grateful for a cable by cable guidance so I may deduce if there is in fact a fault somewhere.
Tags (3)
Hi there
I do not know what "u/s" means when you mention it with HDMI 1
  • Plug both devices (Freesat Box and LG Box) into the TV's HDMI IN ports
  • Plug your aerial cables (or whatever you are using) into the Freesat and LG Boxes
To switch between the devices, press the input source button on the remote control.
If this doesnt work, can you describe what has changed?  Has this setup worked before? Describe what is not working?  And any other details that may assist?
Nobody-in-particular
u/s normally means unserviceable or faulty. :wink:
LOL - easy when you know the meaning :slight_smile:
I like the : FUCT (Failed Under Continuous Testing)
