Connecting to server
keithyorks
I have a Bravia KDL-37EX503 and have a wifi dongle fitted. It can see the internet without any problem. How can I get the TV to see my laptop also connected to my home wireless network. I have done this before using windows media player. I upgraded my laptop to Window 7 now the TV cant connect to the server.
etritd
Check if your WPM is updated, too.
You can also use homestream from http://www.sony.co.uk/homestream
Homestream is smart software that virtually indexes your media library giving easy access to anyone on your home network. This allows you to share your SD or HD videos, music or photos to internet enabled BRAVIA, Blu-Ray Players, Blu-Ray Home Theatre Kits, Netboxes & PlayStation 3 devices.
etritd
